| The Gallery | |||||||
1948 Chevy 1/2-Ton |
Copyright © 1995-2008 Mechanicsville, Maryland |
11 October 2009 Update
From Johan :
Hi there! I joined the Bolters in 2005 but have not been a very active member. I did want to update my Gallery page! There has been a little progress on my project. Last month, I took it for its maiden run around the block. It was a momentous occasion. There was many a time that I thought that this dream would end uncompleted ...... but now she is running. My daughter joined for the ride.
Cheers, Johan 04 April 2005 From Johan: Hi guys. Firstly, I really enjoy your web site !! I am a 40-something mechanical engineer stuck in an IT position. From my years at school, I always wanted to own a V8. Two years ago I received some money from the Receiver (IRS) and bought a built-up 71 Camaro. Although I really enjoyed the car, it started its life as a 6 cylinder and did not have power steering. The windscreen had a crack and it was showing signs of rust under the paint. I also fixed up a nice '68 Chev Caprice (four-door pillarless) for a friend and used it to drive my daughter to the "prom dance." A year ago, I sold the Camaro and decided to go trucking. I bought a sad-looking 1948 Chev with the view to build a Rod from it. After buying the truck, I looked around a lot to see what other guys did. I decided to go the trusted South African route on Rod suspensions, which is to use the Jaguar XJ6 front and rear independent suspensions. These suspensions are modular rubber-mounted sub-frames which I could just bolt onto the truck chassis. Other benefits of the Jag suspensions are that it comes with four disc brakes and the wheel-hub bolt-hole patterns are the same as the Chev patterns. I am also using the standard Jag brake master cylinder and booster. I bought a 350 Chev motor which I matched with a 5 speed Toyota 21R manual gearbox. These went in this week and I cannot wait to start it up soon. I bought a set of new mag wheels and tyres 15 x 10 rears, 15 x 8 front. I also bought a new '48 chrome grill and hood emblems from the USA. Cheers, Johan Kroes
