Joe Lopez's
1967 Chevy SWB Stepside
07 August 2006
# 1610
From Joe :
           This started out as a '67 Chevy SWB Stepside driver we bought in 1991. We kept it a nice driver until April 2004 when it was hit, causing some bent front end sheet metal and a bent frame. Chassis is a 1972 1/2-ton 5 lug, front disc brakes, original dual exhaust, 1972 Big Block motor mount stands, factory front sway bar. Powdercoated gloss black from front to rear.
           I have all of the original GM sheet metal necessary to complete the project except the steel cowl hood that I plan to purchase through Sherman Parts here in Michigan.
           The chassis is ready to go. We are currently working on the powertrain (427 BBC with a 350 auto trans). The cab is currently awaiting some rust repair on the frame mounts, floors and corners along with some minor modifications.
           I have included a few pictures. The red truck is what it looked like originally and the day of the wreck.
Thanks!
Joe Lopez
"Joe67"
Bolter # 11844
SE Michigan
           Thanks for including all those links, Joe. That should be a big help! ~~ Editor
