Gary "GL" Perry's
1954 Chevrolet 2-Ton (6400)
From Gary:
             I've had this '54 6400 about three years now and was driving quite regularly until I tired of shifting and going SLOW on highways. It's more of a novelty, but I do haul gravel and dirt for my one-acre farm accasionally as I am a big do-it-yourselfer!
             It has the original 235 six with about 90,000 on it. Could be rebuilt as was painted black and clean. Leaks oil all-over and out breather tube and valve cover vents.
             I have installed a one-wire alternator and changed to 12-volts (a big improvement), put on all new brake cylinders, shoes, lines, fuel lines, frame wiring, taillights, etc. It was a grain truck with high sides (hate not seeing out the back-window), so changed to lower sides and window opening and made into dump-bed with lift off of a '55 Chevy 2-ton. I used PTO and levers from same truck. I also rebuilt front axle and joints and installed 19.5 radial tires from newer Chevy HD 3500's and motorhomes. They are 8" wide and improve handling greatly! They have the 10-lugs and small center hole that's hard to find.
Gary Perry
"GL Perry "
Bolter # 47
Huntington, Indiana
1954 Chevy 2-ton (driver)
1950 Chevy COE (project)
1955 GMC COE (project)
MM Jet Star 3 Super (tractor)
Copyright © 1995-2010 | Stovebolt.com | Mechanicsville, Maryland
