Double flaring made easy!
by Charlie "Cletis" Hardin
      Bending brake lines and making a new system for your truck can be fun and satisfying... Until you put pressure to it and it leaks because you couldn't get the ends flared correctly! End the despair! Here's Cletis to show you how to ...
Flare with a flair!
      Click a picture to enlarge. To open the picture or link in a separate window or tab, "right mouse" (click on the right-side of your mouse, and it will give you several options to choose from).
tube placement
       This shows the tube in the flare tool clamp.
       The tube has been cut square, de-burred and chamfered inside and out.
       Be sure you have put the tube nut on the tube before you put the tube in the tool.
       The flaring die is inverted to use as a guide for how much tube sticks out of the clamp.
die in place
       This shows the die inserted in the tube and the chilibob attached to the tool, ready to start the flare.
       Be sure to lubricate the die.
       The screw is tightened until the die bottoms out.
       This shows the end of the tube after step one of the process.
       The die has expanded the end of the tube into a bulb shape.
       The anvil is now inserted in the tube and screwed down to collapse the bell shape making the flare.
       Don't screw it too tight.
       VOILA!
       We have a flared tube.
       I squirt some carb cleaner in them and blow it out with compressed air before using.
Charlie Hardin
"Cletis"
1953 Chevy 6100
Bolter # 1113
Parker County, Texas
       Be sure to check out our extensive Forums discussions -- from General Truck talk, Electrical Bay, Big Bolts, Panels and Burbs, Engine and Driveline, Paint and Body, Interiors, Tool Chest -- The Stovebolt Collective can help in your quest and walk you through the mire and magic of working with old iron. ~~ Editor.
v. April 2007
